Good morning all, meanwhile still working on the flak and the halftrack I manage to made this relaxing model of Lunar roving vehicle, model is very strait forward and pleasant to build with no problems what so ever, both astronauts are fully movable, and also the vehicle itself.
Posts by SKOKMA
Hello, just small progress in building, added parts numbering from segments 15-18, hope there will be more time over this weekend
Good morning everyone, today I completed the armor plates around the gun, parts 13. There were no issues building it at all.
Hello everyone! Today I completed the frame of the gun parts 7-7j and mounted gun itself onto the frame . All went well, only problem I encountered were parts 7f (too long) Here is the result.
Hello everyone! Two days ago I started to build my first paper model after a long modeling pause, here it is the Halinski's FLAK 38/20mm, the final model will be attached to "halftrack" Sd.kfz 250/3 Greif by GPM.
So far I made base of the flak, I follow the build as described by the author, so far there were no problems except with those parts 1d, 1j, both parts were too long but it is not a problem to make them to fit. Also the bottom part of section parts 5 is too big and it won't fit the inner ring of the base, so it needs trimming before glueing on the bottom of the part 5a, and finally the parts 1e wont fit as the author didn't calculate the thickness of the paper, therefore i cut those in to pieces and shortened them as required.
Later on today mean while waiting for the parts to dry (7) I also made the body of the gun. The results can are here:
