About the Wasp, I emailed the guy about 1-2 years ago to see if he kept the files or if he intended to have his kit published and he answerd he had not kept the files nor had the kit up to be published. It was a great loss as you can see his Wasp was excellant. There are literally a dozen or so home manufactured kits from the 1950s to present. The Watkins kits is the most prominent to mind. A good range of subjects a bit basic but "detaileable", but no carriers. Barry published a few of his excellant ship models on the ecardmodel site is a an example of the 21st century digital kits being made from these home manufacturers. You can probably sit tight with the available kits. By the time you are done building that group someone will have designed and published the other WW2 carriers.
Posts by cmdrted
Also by Maly is the USS Essex CV9. They have reprinted it but still have a big glitch in colours particulary the flight deck and the other decks. They remain brownish and should be a deck blue colouring. In 1/300 scale
If you look at out of print but available at times
GPM Hiryu 1/300 scale
Halinski Enterprise CV6 1/300 scale
Halinski Victorius 1/300 imo not as good as the JSC version
Betexa made a "jeep carrier" I think the Gambier Bay very basic kit.
Way out of print but curiously available on GPM site was the HMS Hermes in 1/400 scale. Poor quality paper, non existant instructions, 2d planes but a basis for repainting and detailing, in 1/400 scale.
Fly model Akagi in 1/300 scale, excellant detail can be enlarged with no loss of detail -
My first finished ship in years!
hier ist schwarz und weiss bildern... und drie mit farben bildern...
Thankyou Zaphod. I finished this ship and have many pictures. There were several shortcuts taken to complete her but this is my first completed ship for many years so I didn't add the many more details that could've been...
Thankyou Jorg. I have admired your work with these kits for quite some time. Many years ago I started with GPM 1n 1/400 scale and after a few kits I was not happy with the level of detail so I switched to 1/250. This was large enough for detailing but I soon ran out of room. I bought alot of GPM barrels in 1/200 scale but now that I switched back to 1/400 i needed to do something with the barrels, so viola', I pressed them into smaller service. I started with the 25mm Japanese barrels but they loooked to thin. I think I'll use them to represent the English 40mmm pompom guns, who knows?
Next on modification was the island. I repainted, poked out and backed the portholes and windows, made up some searchlights and added on teh surface details to make it look less flat...
The aircraft needed modified also. The kit planes were pretty good shape wise but lacked surface details. I used the markings on the free downloaded airplanes on the Konkradus sites as a guide to repaint the JSC wildcats and avengers...
These were modified and placed in the appropriate spots. I used 1/400 laser cut railings from papermodelshop.com. I also reworked the 40mm and 20mm guns to look a bit more like the prototypes. I used GPM 20mm barrels for the 40mm guns, worked out pretty good. You can see the stock guns in the photos...
I'm finishing up the JSC Repaint, the next series is the flight deck. It was able to be placed inverted and weighted to insure it comes out flat. Also I strung some silk thread arresting cables across for better detail... -
here are the rest of the pics of the rear deck, I built up/ borroed the deck 5"/38 from the Maly Essex kit and the twin 40s were modified Fly model guns. Included are 2 of the stock guns from the original JSC kit...
The next bit is finishing the forward and after deck. The kit has plain details and 2 empty towers aft that I think has small gundirectors in it. I made up a few directors, closed of the huge openings in the after hull with paper tarps and railed the area off with JSC laser cut railings. The foredeck received the same treatment...
This is the next edition in A4 sheets. I see from the JSC website that they have struck this from the available list maybe they are repainting it in their new CAD format.
Viele Danke, Gert! I have watched too long, it was time to participate
The next part was putting the colored hull skins on the plain under structure. For no particular reason I started port forward, continued aft the aft starboard and the forward stb piece. There is a little overlap that can be either trimmed to fit edge to edge or you can overlap the excess hull. I chose to trim the pieces I think it looks better that way. Here are the sequence of picures along with some of the aft deck being finished...
I forgot the last post picures! Sorry!
As before the box structure was built up. I started on the forward and after decks before skinning. The forward deck was very plain, so I added a better anchor/winch/chains gear. Also I made up some fire hoses and made the bulkheads a little more 3D. The portholes were punched out and a green backing was place to give more depth. I also made up some watertight doors. Tou can see some early progress of the new deck and 2nd pic is the kit deck. The 3rd pic and arrows show a fault in the kit design the fore peak has a big gap that needed to be included with the new deck...
JSC uses a differant method for their ship hulls. The have an inner plain structure with minimal formers, some bulkheads and little to no laminated formers. After building this main inner structure the colored parts are skinned. The good thing about rebuilding something you started before you can correct mistakes, yours and the kits!
Hello all this is my first posting here. My German is very bad perhaps I can learn alittle from the forum. Guten Abend vom Avondale, Pennsylvania USA. I've started on the standard JSC Card about 5-7 years ago and never finished. This fall I decided to have another go at it. But the colors seemed to bother me, particularly the flight deck so I bought another kit scanned it and paintshopped the colors to be more appropriate. There will be comparisons of old and new with this building report. Here is the old flight deck with some aircraft on it and the new colors. The 2nd pic is the new hull aft overtop the old. And some other coloring of the flight deck...
