T-65 X-Wing by uhu02
  • Hi everyone, again!
    Starting a new model—I'm on a roll with Star Wars right now. I just can't stop and get back to armor models yet! :) This is one I've wanted to build for a long time: the X-Wing designed by uhu02. Having already built his TIE Interceptor, I know exactly what to expect: a thoughtful, precise design with unique assembly ideas and minimal errors. So far, that is exactly what I've found.
    This is the X-Wing "Red 3" cutaway version, so a lot of the inner systems will be on display. He also managed to design it with movable wings, just like the real thing. There is an incredible level of drawn detail here, including tons of pipes and internal machinery. Because of that, I still haven't decided if I will build it completely "as is" or add some physical greeblies here and there. I don't want any added details to pop out too much against the printed texture.
    Since it is a free model, I printed it on Canon Matte Photo Paper (170 gsm) and coated it with Americana varnish. Interestingly enough, this is the exact same paper uhu02 used for his original build, so I am expecting a highly precise assembly. The model consists of 11 pages, plus one solid grey page meant to be printed on the back of pages 10 and 11.
    As stated on his blog, this is the Red 3 version (Biggs Darklighter's fighter). There is a short article about this particular starfighter that you can read here.
    Because uhu02 already has his original build thoroughly explained with assembly pictures, I won't do a hyper-detailed step-by-step build log. Instead, I'll just showcase the build from my perspective, sharing general notes and pointing out any template errors (though I don't expect many!). Additionally, I'll be using markers to paint the edges this time, as the model features a lot of solid colors that make edge-painting very clean.
    The Assembly Begins
    I went by the numbers, and first up were the front wing beams (parts 1–18). At first glance, looking at the instructions and pictures can be very confusing—there are just so many parts and numbers. However, once I cut everything out and followed the steps, it became incredibly smooth and logical.
    In the end, I got two beams that rotate smoothly on an axis. It's a genius piece of engineering to design the mechanism in layers so the wings can remain fully movable. There is a lot of laminating involved, but once assembled, it creates a remarkably sturdy structure that is incredibly satisfying to hold and rotate.
    In addition, central axis was built.
    The back beams went together the exact same way. Overall, if you cut exactly on the lines and glue with precision and patience, everything fits beautifully. It is engineered right down to the millimeter.
    I've just dry-fitted the assemblies onto the central axis to see how it looks!
    There is a tiny error, that doesn't affect anything - no numbering for part 15
    Stay cool! :thumbup:
    Igor
  • May the Force be with You!
  • Thank you Heiner and Chris
    I continue to build the frame.
    Next up are the rear spars for the wings. Each one consists of 4 layers, and once glued, they are remarkably sturdy. You definitely have to pay close attention to the numbering and direction here.
    Uhu02 even accounted for the bending angles by designing each layer with a slightly different length, so when they are bent, they align perfectly with the layer above.
    I also assembled the middle spars. Another thoughtful detail from the designer is that he includes a guide to check your laminated spars and beams for the correct thickness.
    Mine turned out absolutely perfect, which proves that the 170 gsm photo paper I'm using is exactly right for this kit.
    Then, I connected the spars to the front and rear beams:
    First, I attached the middle spar to the rear spar, ensuring the side with the black holes points inside the wing.
    Next, I joined the middle and side spars to the front beam at the designated alignment marks.
    Finally, I attached the rear spar to the rear beam.
    Here, I noticed another creative solution from Uhu02: when I assembled the rear beam, I saw that the edges formed a series of tiny steps or "stairs." This was completely intentional!
    The rear spar must be glued at an angle to the beam, and these stairs provide a perfect positioning cradle for that exact angle.
    Everything aligned flawlessly, and the central wing shaft was inserted.
    A huge warning for anyone building this: Do not glue the shaft to the beams! If you do, you won't be able to open the wings later.
    The inner beam sides that touch the shaft in the front and back move in opposite directions, so gluing them will completely lock the mechanism.
    I know it's highly intuitive to want to glue it for extra structural strength, but don't do it!
    Additional details will be added to the frame later on, and at a much later stage, the shaft will be securely locked inside the fuselage by the front and rear bulkheads anyway.
    The frame is now fully assembled, and the wings open and close exactly as designed!
    Igor
  • To complete the wing frame, I assembled the walls that separate the engine compartment from the rest of the wings. Here again, the lamination method was used to get incredibly stiff parts. I followed uhu02's advice to roughly cut out the parts for lamination first, glue them together, and then perform the final precise cuts along the lines. This technique gives you a perfectly uniform, solid edge.
    There was a minor template error here: parts 66b, 69b, 72b, and 75b are the wrong width. If you glue these parts to a vertical wall (like part 65, for instance), you have to butt-glue them edge-to-edge rather than underneath. When done this way, the width turns out to be too wide, so I ended up trimming the excess off. Interestingly, the outer counterpart pieces (67b, 70b, 73b, and 76b) fit perfectly fine because they naturally cap the edge of the vertical wall.
    Everything is now assembled on the frame, and the structure is remarkably stiff.
    Igor
  • I've started assembling the upper right wing.
    Usually, I like to work assembly-line style when dealing with repeating parts across multiple wings.
    However, this specific wing features the cutaway sections that expose the interior systems—like the power coupling in the middle and the deflector shield projectors close to the wing root.
    That's why I decided to concentrate on just this one wing for now.
    Everything went smoothly and fits perfectly. You do have to figure out one of the cutouts on part 112 for yourself, though,
    because uhu02 provides options to build the wing as standard without showing the internal machinery.
    Rolling the parts went well because I wetted them just a little bit before shaping.
    I also used a friend's advice to roll them down to the desired diameter inside a tight, defensive sleeve made from a rolled-up sheet of standard 80 gsm paper. This worked incredibly well.
    One thing to pay close attention to: the upper wing casing aligns right with the front of the leading edge.
    Because of this layout, it will overhang slightly in the rear, but that is fully intentional in the design.
    You will need to align the bottom casing using the upper one as your reference.
    Igor
