Top Qualität ! - Топ ОК ! Gruß Peter aus Potsdam
Vielen Dank Peter60.
Мойн, Зафод, да,
именно так. И это чертовски весело для меня.
Если, как здесь с Грелжаком или Грабовским, можно рассчитывать на то, что конструкция хорошо продумана, то все отлично.
Начинайте клеить!
Good job!
Maybe make the paint a shade lighter?
I present a model of the front-line fighter MiG-23PD, publishing house "Cardboard Factory".
We can safely say about the model - it is not finalised. Many solutions are not shown in the manual. You constantly have to think about a few steps ahead. There are no markings on the parts that show that it is necessary to make a cutout. For high-quality assembly, you need to have two magazines in your hands.
The result is in the photo.Greetings, dear community!
I decided to finish the section behind the cockpit. Mr. Mistevich has places where the thickness of additional elements is not taken into account. In this section - internal glazing braid + glazing film = skin did not match by 1-1.5 mm. I had to carefully tear everything off and sharpen the frame.
I missed the aircraft cannon in the instructions. I had to cut and glue it to the already finished body.
Greetings dear community!
I am starting the model of the Lockheed F-104G "Starfighter", published by Kartonowa Kolekcia, issue 17. The "Starfighter", the first to reach a speed twice the speed of sound.
Welcome.
Started with the external fuel tank (PTB). To test the paper for bending. The second set of external fuel tanks, I will not glue yet. I plan to arm it with a pair of guided missiles, air-to-air class AIM-9B Sidewinder.
The instructions in the magazine are very compact and show a large number of parts on one sheet. On this sheet of instructions, almost 90% of the information is the cockpit of the pilot's cabin.
Очень хороший и аккуратный. :палец вверх:
Продолжение.
Continuation.
Continuation
Finished Su-11 "Fishpot-C", from Angraf.
About the model. In the magazine, the model is printed in two complete sets on different types of paper - coated and Whatman paper. I took sheets on Whatman paper (metallic). I had a magazine with ready-made cut-out parts.
During assembly, it turned out that the ready-made parts were smaller than necessary. The instructions are very unclear. The model itself is not difficult - "The tail was attached to the pipe, .." I think I successfully solved the puzzle with the chassis assembly. The size of the wheels is smaller than necessary in this scale. I took the missiles from another development, the author is Alexander Burdin. Ready-made ones, they are better. The canopy is homemade. The model turned out to be not small (53 cm), it was not ready.
Actually, I also have the model you mentioned, and I plan to start building it immediately after this project is completed.
For a new model, you can use ready-made 3D paper decals. As these.
