Posts by Armando
My first three models made from reprints of French postcards given free as product promotions. I think (?) they originate from the 1940s-1960s.
I like the simple charm/character of these, so I made them as near as they were intended to be made, with the exception of additional card reinforcement and modern glue/varnishes. The construction designs/prints didn't quite work on the Cinzano and Furnex vehicles, with gaps and unwanted printing, which I disguised accordingly.
I have quite a few more of these to do.
Does anyone else build Metal Earth models? I've done a few. I've just completed this (Chinese equivalent) model of the Hawker Hurricane.
I only paid £1.70 (2 Euro) for it, from TEMU.
It went together reasonably well. Although not strictly accurate, it is instantly recognisable as a Hurricane.
Being metal, such models do pick up lots of fingerprints during the build, so I always soak them in warm soapy water afterwards then rinse in cold water and allow to dry.
Thanks, Heiner! I like the steerable tail skid....
The front edge has to be trimmed after gluing.
Completed, on a custom-made base.
The front light units, which were assembled individually and inserted into the cowlings, can be seen, together with the positions of the three wheels.
I will post photos of this, together with my Reliant Regal three-wheeler, in the Gallery.
All completed!
Although this is already completed, I took a few photos during construction. It's a very simple build. I scaled it to my preferred scale of 1/50.
The print used to be available (free) from 3-wheelers.com. I sprayed the sheet with acrylic varnish before starting.
Diagram showing construction of components.
I started by making the three road wheels. The front wheel is different to the two rear wheels.
I decided to reinforce the lower body with cardboard, between the front wheel box and rear mount.
The completed 'chassis', showing rear axle, lights and front wheel box.
Thank You!
When the Plane feels alone you must built a Tucker Snow Cat for society!
Greetings
Claus
I have one of those waiting
Hello Armando,
very nice built!
What Papermodel do you use?
Greetings
Claus
That's a Zio Prudenzio print, attached.
Personally, I'm a fan of vintage and antique paper models for the same reasons Armondo related in his post. So thank you for posting these.
Also, I wonder if the U.S. Mail van is a simplified (or possibly inspired by) Studebaker Zip Van circa 1963?
Here's a source: https://www.oldcarsweekly.com/features/car-o…ek-1963-zip-vanI've attached a photo from the website link also.
MichaelThanks, Michael. Interesting photo. I see the resemblance 👍🏻
Very pretty and nice!
Thanks, Christoph!
I have just completed two model Autorails.
The Bugatti Autorail Rapide:
The content cannot be displayed because it is no longer available. The content cannot be displayed because it is no longer available. The content cannot be displayed because it is no longer available. This print, I think, dates from the mid-20th century. Slightly inaccurate, it is missing 4 portholes and the bogeys only have 6 wheels. I made new bogeys, with the correct number of 8 wheels. I also added layered doors and coloured the lights (I think the lights are printed upside down). The scale is a very approximate 1/120.
The second one is based on a vintage French tinplate toy:
On this one, I made the 4 wheels able to rotate.
Here are the two together:
Recently-completed, this is a nice little print designed by a follower of mine on Instagram.
It does contain some inaccuracies, but these can be sorted out (and improved upon) during the build process.
I glazed the screen, added some rigging, and made the undercarriage more realistic.
The aircraft was built in 1945, prototype numbers only. Its 'boxy' appearance is down to the simple plywood and fabric materials. The fuel tank was mounted externally, in front of the screen, the engine being gravity-fed. The undercarriage was a simple fixed wooden design.
Very cheap to build, it was to be flown by a Kamikaze pilot. Japan ceased hostilities before the aircraft could be used.
Just completed my first Fiddlers Green model. The Sopwith Tabloid floatplane was built for the 1914 Schneider Trophy race (it won).
The model came out better than I expected. It wasn't an easy build, and the fit of some parts left something to be desired. I added rigging (a bit over-scale, but looks okay).
I'm looking forward to doing more from Fiddler's Green.
Display More
Hi Armando,
it's a very nice, little train. The Micromodels range is a really
nice voyage back in time. Simple but nice graphics, not so easy
to build but a little bit of the 40th and 50th in every one of them.
I'd appreciate more of this models...
Yes, I've made several Micromodels. Lots more to build 😀
Na ja…
Acquired taste, yes ..... I like them and view them as a part of social history and simpler times 😀
Two simple paper vehicles just completed. A Volkswagen Beetle and a U.S. mail van.
I found them on Pinterest and printed them out in approximately 1/50 scale.
Quite old, they have some charm. I like how the postal van has external fold lines and tab positions marked. And the Beetle is obviously a bit 'square'. I added Tamiya clear paint for the lights, thickened up the wheels, and incorporated cardboard stiffeners. A coat of acrylic spray varnish seals them.
I couldn't identify the type of mail van, so it's possibly just made up. It looks 1950s/60s in style.
Just completed this little model from a print that I found on the internet. I made it for my daughter, who has a Nissan Cube..... I thought she might display it when she takes her car to one of the many car shows she attends. She is a fan of Japanese cars.
I coloured the lights with Tamiya translucent paints and thickened the wheels. I made the base from cardboard and a print of the Rising Sun flag.
That's pretty fantastic!! 👍🏻✂️
Nice built. I Think its from the Paperdiorama-Site:
>https://www.paperdiorama.com/paper-models/c…y-who-loved-me/
No, it's not that version, but I like that one too!! Thanks for the link - not heard of it before......
This is a model of the car which starred in the 1977 supernatural film starring James Brolin, about an evil car.
From My Little Paper Vehicles, I added hubcaps and widened the wheels. The actual vehicle was based on a Lincoln 'Continental' MkIII, customised by George Barris (who designed the Batmobile from the 1966 TV series).
