Two camouflage versions of the model designed by Lukasz Fuczek are available.
Please visit http://www.gremirmodels.com for more information.
Posts by GreMir
I'm very happy to announce that Michal Rafalski offers today his first design, Japanese Type 94 TK tankette. Model is offered in three-color camouflage, same as in printed format published by WAK.
For more information, please visit http://www.gremirmodels.com -
Thanks to great help from Greg Perry and Tim Crowe I'm happy to announce that CMP Ford F15A is now available.
Please visit http://www.gremirmodels.com/ford_f15a.htm for more information.
Here are few photos decent enough to be shown. Turns out that photographing very light colored model in direct sunlight is very difficult
Thank you Helmut.
Since Shomo was flying tactical reconaissance missions, he was more likely to carry bombs than external fuel tanks so I glued 500lb bombs on the underwing racks.
Bombs and propeller blades came from a plastic model of the P-51, same as the pilot.
Final photos will have to wait until daylight. -
Instead of mounting wings to the fuselage, I decided to copy the idea from the Mustang Mk I and installed the wing fillets instead. This way I was able to mount them without risking smearing glue all over the fuselage. They fit the fuselage very well, but the lower part required some very carefull coaxing into place - problem was the fact that by lowering the flaps I removed the part of the wing to which the fillet was supposed to be glued and had to make up for it.
Right wing guns.
I used 102% shrouds from the set provided by Dave (again, BIG THANK YOU! ). Barrels are 20ga needles wrapped in 0.5" x 0.5" copy paper and painted silver. Black tubes came from the set provided by Dave.
Shrouds require delicate handling but they fit the wing perfectly and really add to the look of the plane.
Work continues
First photo shows my method of strengthening the wing. Additional spar was added to prevent the skin from sagging since I cut off the control surfaces.
I always reinforce large areas with extra layer of card between the ribs - does wonders if you tend to grab the completed plane by the wing
Second photo - excellent fit, no problems at all eventhough this is a tricky part in the Mustang.
Third photo - here I run into a small fit issue. Both wheel wells are done as one part but when I dryfitted them to the wing they came up 1mm short. Easy to fix though. I separted and glued them to the wing skins and then added strip of card to close the gap between them. It has different color than the wheel well, but it's close enough.
Last photo shows the formation lights. It's not very well visible, but I cut them off and re-glued them from the inside of the wing and used Micro Kristal Klear to create lenses.
Today I will try to work on the second half of the wing - will see how it goes with the family
Started on the wing.
Wing frame as designed will work, but in my very personal opinion it is a little weak and prone to bending so I used scrap card to reinforce it. The weakest section right now is the center, but wheel wells will take care of that.
I shortened the ribs because I will be completing the wing with landing flaps lowered. The cut out parts will be used in the flaps. -
The windscreen kept bothering me for a few days until it hit me - it had wrong color...
I see the Undertaker every day I sit at the computer (my desktop screen ), but I just realized that the framing should actually be silver, not olive green. Delicate work with scalpel blade helped in removal of the one in place and printout of "The Troll" Mustang provided the replacement so no harm done
Tail - I separated control surfaces (will be installed later) and added some card to close the opening. Next step of course was to join both halves of the fuselage.
Next came segment directly behind the cockpit. Inside of it will be visible (not much, but enough to be noticed) so again I added some scrap interior color to hide the white card.
Connecting this segment with the front fuselage was 99% succesful...
Right side alligned perfectly, left side ended up with a slight shift in the yellow bands, but I'm not going to worry about it too much.
I switched to the tail and as before I decided to make my life difficult [Blocked Image: http://www.papermodelers.com/forum/images/smilies/rolleyes.gif]
In the wheel well I added tube rolled from regular copy paper to reinforce the tail wheel. Dave provides optional parts for the vent openings so of course I wanted to use them [Blocked Image: http://www.papermodelers.com/forum/images/smilies/smile.gif]. The only change I made was to actually cut out the opening so when the vent is glued in place it will look more realistic.
Ok, here I decided to have some fun with the build - time will tell how much damage I did [Blocked Image: http://www.papermodelers.com/forum/images/smilies/rolleyes.gif]
In order to have the exhaust shrouds recessed, I decided to cut out black fields in the nose of the plane and glue black stripes underneath.
For the moment they are only secured at the front and top to make sure that I do not deform the segment.
I must say that I'm making my life difficult here...
I've been pestering everybody about this particular Mustang for a veeeeeery long time, so when finally Dave created one and I had a free work bench it was time to start the build
Cockpit is very sparse, but considering the fact that I will insert the pilot none of it would be visible anyway (and I don't really enjoy all those tiny boxes ).
As you can see there is not much room inside, but with small modification (cut off the sides of the seat, front of the canopy and the very bottom part of the dashboard) pilot fits inside and that what counts for meFor those who don't know the story of Bill Shomo - he is the only American ace that was not (technically) a fighter pilot. He flew in the 82nd tactical Recnaissance Squadron. During his 200 combat missions he only saw 14 Japanese airplanes and destroyed 8 of them. Out of those eight, seven were destoyed during single mission earning him Congressional Medal of Honor.
Will's newest design, experimental high speed interceptor Republic XP-72 is now available.
This is one of the friendliest forums around so I'm sure there will be plenty of help available, but please be more specific - do you you need help with ordering the model or building models in general?
If you are interested in pre-printed version of USS Iowa (or any other of Carl's ships) you can contact him directly (I will provide email address upon request) or through me and I will forward your request to Carl.
You can also place an order through my web page and add a note "printed copy" and I will transfer your order to Carl.
Newest pre-dreadnought battleship, USS Iowa BB-4 is now available.
Please visit http://www.gremirmodels.com/ for more information.
Rafal Ciesielski offers his model of P-82/ F-82 Twin Mustang.
Model is available in three variants - P-82B. F-28F and F-82G and in six different markings
Hi,
I just completed the model yesterday and wanted to show off a little
Slight differences in color between fuselage and wing fillets are the result of required corrections to color transtions and reprinting the parts few months later than the rest of the model. Cockpit is occupied by RAF pilot in tropical gear from Master Detail. Gun barrels are 1/32 scale British 0.303cal Brownings offered by Master Model and wheels are 1/32 weighted resin wheels from True Details.
